Wheel Slip Percentage
Postby rayhall on Wed Sep 01, 2021 12:08 pm
I am setting up my C125 display and I want to show wheel slip percentage. This is not in the CAN data stream. I do have front and rear wheel speeds. If there some way to put a calculated value in the display by adding a formula
Ray.
rayhall
Re: Wheel Slip Percentage
Postby David Ferguson on Wed Sep 01, 2021 12:26 pm
In your C125 Config, use the menu Calculations->Speed and Distance... Configure Ground Speed, Drive Speed, then enable the Slip calculation -- add that channel to your display.
Postby rayhall on Wed Sep 01, 2021 3:10 pm
David, Thank you
Ray,
rayhall
