Mx00 Options enabled check requests
Re: check M600 options enabled
Postby Stephen Dean on Mon Jul 12, 2021 10:31 am
Tunedgether wrote:Hello,
Please check options enabled of M800 serial 13003-09874. What has upgraded?
Regards,
Paisan R
Hi Paisan,
That M800 has the following options enabled on it.
M800 # 9874
Options
28118:OEM ENABLE
28105:ADV FUNC
28101:1M LOGGING
Re: Mx00 Options enabled check requests
Postby Tunedgether on Tue Aug 17, 2021 2:48 pm
Please check options enabled of M600 serial 13001-02160. What has upgraded?
Regards,
Paisan R
Tunedgether
Postby Stephen Dean on Tue Aug 17, 2021 2:53 pm
M600 # 2160
Options
26110:ENABLE
26101:512K LOGGING
26102:SINGLE LAMBDA
Postby Vlad on Wed Oct 13, 2021 7:11 pm
Good day, i will have the following ecu in the shop, on a hillclimb evo, and i would like to know what functions are enabled in it, the car is out of the country and the client dose not have a UTC. Thank you
M800 goldbox, SN:13001-06435
Vlad Pescaru
Vlad
Postby Stephen Dean on Thu Oct 14, 2021 8:53 am
Hi Vlad,
M800 # 6435
Options
28110:ENABLE
28105:ADV FUNC
28101:1M LOGGING
28104:PRO ANALYSIS
28102:SINGLE LAMBDA
28112:DRIVE BY WIRE
28116:CAM CTRL
Postby Kenny Bahd on Fri May 19, 2023 6:05 pm
Hi, could you tell me what options are installed on this M800 ser# 13001-05485. Checking if it has the functions I need.
Thank you, Kenny
Kenny Bahd
Postby Stephen Dean on Mon May 22, 2023 10:08 am
M800 # 5485
Options
28110:ENABLE
28105:ADV FUNC
28101:1M LOGGING
28102:SINGLE LAMBDA
28103:DUAL LAMBDA
Postby oficinademotores on Fri Jan 26, 2024 2:05 am
Hello, I have an M 800 with serial 1735, what options are installed?
What is ENABLE M800?
Thank you
oficinademotores
Postby Stephen Dean on Mon Jan 29, 2024 9:15 am
The Enable code is the code that enables the hardware, without this code, the hardware doesn't work.
M800 # 1735
Options
28110:ENABLE
28101:1M LOGGING
28104:PRO ANALYSIS
28102:SINGLE LAMBDA
28112:DRIVE BY WIRE
Postby impLODE on Fri Mar 29, 2024 6:27 am
M800 Gold Box : S/N 11562
Please let me know the options enabled.
Thanks a bunch!
impLODE
PreviousNext
