LTCD strange behavior
Postby OlegD on Tue Aug 10, 2021 10:09 pm
Hi, I'm experiencing strange LTCD issue, it was ok before. It's impossible to switch lambdas in this configuration without pulling the engine. M1 GTR package. Where to look for the problem? Or the sensor is dead.
Motec lambda - Copy (2).jpg (99.32 KiB) Viewed 7979 times
OlegD
Re: LTCD strange behavior
Postby David Ferguson on Wed Aug 11, 2021 2:23 am
Seems obvious -- bank 2 Lambda sensor. But could also be a broken header or other exhaust failure upstream of the sensor.
While you have the engine out, perhaps you could relocate the sensors bungs in the exhaust to make them more replaceable (like by just removing the exhaust).
Postby OlegD on Wed Aug 11, 2021 11:06 am
David, very strange thing that it works sometimes. Exhaust is fine as well. I'm more inclined to think that this is the wiring issue and not a dead sensor. Car was totally fine a few weeks ago on the dyno and didn't move anywhere waiting for the fuel pumps.
OlegD
Postby David Ferguson on Wed Aug 11, 2021 11:57 am
Any chance your wiring has melted on the exhaust?
Postby Stephen Dean on Thu Aug 12, 2021 12:25 pm
Can you log all of the channels for the two LTC's and post it.
Postby MalcolmG on Thu Aug 12, 2021 2:55 pm
Any chance the lambda sensor is too close to the alternator? I've had intermittent issues like you describe in an application where the sensor was about 50mm away from the alternator; changed sensors 3 times before clocking it 180 degrees around the pipe and the problem went away permanently.
MalcolmG
Postby OlegD on Tue Aug 24, 2021 1:46 am
Log attached. Maybe that's fuel contaminated with some additives? It's a strange batch of "e85" blend supplied by one company, that shows "ethanol" content as 106% now. Some Methanol?
New spark plugs, leak tested the engine, checked the exhaust, wiring. All seems to be ok. No audible knock.
Alternator is far away. Wires not melted.
S1_#839_20210803_140933_EXPORT_LAMBDA.ld
(873.68 KiB) Downloaded 877 times
OlegD
Postby Stephen Dean on Tue Aug 24, 2021 9:28 am
Water contamination of ethanol can also lead to the sensor reading more than 100%.
