pdm15+keypad turnoff output help
Postby slmawi on Sat Aug 07, 2021 4:42 pm
hello
need help spend 4 hour try many method can't get it right
every thing work but only problem i want to solve is
when i press ign (keypad button 1) i can turn on all keypad buttons as master
when turn off ign button turn off all output , problem is when press again ign button not reset the output what was active turn on again and want it off only ign button is on
example:
ign button + fan button active output on
ign button off = fan output off
press again ign button only = fan turn on ,i want to be off reset
i attach the file
thanks
FT600 new wiring.pdm
(119.68 KiB) Downloaded 537 times
slmawi
Re: pdm15+keypad turnoff output help
Postby adrian on Mon Aug 09, 2021 11:28 am
The Master Shutdown isn't a reset, it simply turns off the outputs that are configured to use it when your Master Shutdown condition is true. When it becomes false the outputs will turn back on if the conditions that drive them are still true.
If you want a reset button you should use it to reset your functions. So for example your "Function-IGN" function has a toggle based on an ignition button. Add your keypad reset button to the reset of this toggle (see below).
PDM Toggle Reset.png (45.18 KiB) Viewed 4056 times
Postby slmawi on Mon Aug 09, 2021 10:13 pm
thanks for advice its work
thanks
slmawi
