Rotary Controls
Rotary Controls
Postby pooh_bear on Thu Aug 05, 2021 10:59 am
Hi All
In the process of planning the installation of a M600. A few questions regarding rotary switches if i may.
I intend on using two switches. One to allow two maps, The other to adjust slip for the TC.
As i understand it:
1) DSM-4 outputs a logic state. DST-4 outputs a voltage based on the value of the resistor selected.
2) DSM-4 is required for switchable maps.
3) It must be wired to AT5 or AT6.
4) Is DST-4 suitable for slip? i.e. enough positions?
5) Slip switch uses an AV or an AT input?
Thanks in advance.
pooh_bear
Re: Rotary Controls
Postby NathanB on Fri Aug 06, 2021 10:22 am
A DSM-4 is suitable, provided you are using V3.3 firmware (or newer) for the multi config system to operate.
4 positions can be enough once the traction system is calibrated. Most people that use a 9 position switch in my experience don't use all of the available positions.
For the DST-4 you will use an AV input, as you will be using your dig inputs for speed measurement, and you don't require the 5V pullup of the AT input.
Re: Rotary Controls
Postby pooh_bear on Wed Aug 18, 2021 9:57 am
Thanks Nathan
A clear explanation!
pooh_bear
Users browsing this forum: Google [Bot] and 12 guests
