Is it possible to add a simple speed output out of an SDL to drive an Odometer? (trip meter in a rally car)
At the moment im getting speed and distance from a GPS and coverting that to groundspeed. From groundspeed I generate Lapdistance by having a condition trigger the beacon. I set a Condition to trigger an output at every change of ten meters lap distance. This helps a lot since you done have to fit odo probes that get hit by rocks.
Could Motec make this a bit easier to do in future releases please? Running it from the SDL`s Odometer is not suffiecient since its base resulution is 100m. At least 10m resolution is needed.
M
