Hi guys. Im at the planning stage on a pdm30 / pdm15 set up.
The only part I cant work out is how to wake the PDMs up. There does not appear to be a 12V in switch
when I look at the pin out.
TrophyBurro wrote:Just a switch outside of the can network that will turn everything off in emergency
fuel pumps mainly.
greenamex2 wrote:TrophyBurro wrote:Just a switch outside of the can network that will turn everything off in emergency
fuel pumps mainly.
So you want a simple "master switch" input and set any outputs you want it to shut down.
