M84- 4 CYLINDER, 4-STROKE, SETUP SEMI SEQUENTIAL
Postby dr350 on Tue Jun 29, 2021 1:17 am
Hi
I use M84 on a 4-cyl 4-stroke engine, which has no camshaft signal.
SETUP:
Number of Cylinder: 24
crankshaft signal: 60-2
REF / SYNC Mode: 8 (2 Missing teeth once per cycle)
Firing order: 1-3-4-2
Number of coil: 2
Wiring Ignition:
IGNITION 1: (CYL: 1 AND 4)
IGNITION 2: (CYL: 2 AND 3)
WIRING FUEL INJECTOR:
INJECTOR 1: CYL 1
INJECTOR 2: CYL 3
INJECTOR 3: CYL 4
INJECTOR 4: CYL:2
I was reading in this post: viewtopic.php?f=47&t=2689
I understand that in this mode (8) works in group fire (SEMI-SEQUENTIAL)
The injectors fire 2 times every 360º.
Question:
In what order do the injectors fire: Group 1: CYLINDER 1 and 4 or 1 and 3?
Group 2: CYLINDER 2 and 3 or 2 and 4
The injector duty cycle correspond every 180º?
Thanks, regards!
dr350
Re: M84- 4 CYLINDER, 4-STROKE, SETUP SEMI SEQUENTIAL
Postby dr350 on Wed Jun 30, 2021 10:28 pm
Excuse me for inciting, surely it is a very basic question, but I wanted to evacuate this doubt.
Thanks, Regards!
dr350
Postby Stephen Dean on Thu Jul 01, 2021 10:26 am
In this mode it will fire the uneven Injector outputs in the first batch, and then the even injector outputs in the second batch 360 degrees later. This means that the injectors have to be wired in the correct firing order to the ECU so that the injectors are fired at their correct timings.
Postby dr350 on Thu Jul 01, 2021 11:16 pm
Thanks for Your reply.
Is mode 8 correct / optimal for a 4 cyl, 4 stroke engine without a sync sensor on the camshaft?
The injector duty cycle, how many degrees is it?
Thanks, Regards!
SDean wrote:Hi,
dr350
Return to M84 ECUs
