M1 prefconfigured alarms migrated to dash to display?
Postby Suprafied on Fri Jun 25, 2021 9:48 am
What is the best way to set up the alarm notifications in a C127 when using pre-configured alarms in M1 firmware?
Is this even an option or must each existing alarm be programmed into the C127 as well?
DP
3.4L 2JZGTE with M150 and a C127
Suprafied
Re: M1 prefconfigured alarms migrated to dash to display?
Postby NathanB on Sat Jun 26, 2021 5:29 pm
There are 2 dfferent types of alarms you could be referring to.
The first is your M1 Tune alarms, which don't function outside of the tune software.
The second is the channel warnings. These can be used for triggering alarms in the dash. They need to be enabled and configured in the ECU, and you need the channel to be present in the comms template in the dash.
When the above is done, you can have an alarm triggered based on that warning channel state. You still need to do this setup in the dash, however once it is setup, any changes you make to the conditions of the warnings will affect the triggering of the dash warning, without having to go into the dash config separately to update alarms.
Using Warning state for alarm
Dash alarm.PNG (24.98 KiB) Viewed 4354 times
Channel warnings in dash templates
x640 warning channels.PNG (70.76 KiB) Viewed 4354 times
M1 Tune channel warnings
Channel warnings M1.PNG (84.78 KiB) Viewed 4354 times
Postby Suprafied on Mon Jun 28, 2021 1:55 am
Nathan,
Thanks for clarifying and showing that example. The unit is now transmitting the warnings as presented.
Suprafied
