Motec M4-8 9502 006 EPS B2
Re: Motec M4-8 9502 006 EPS B2
Postby Doug-WG on Thu Jun 24, 2021 4:52 pm
Hi, and thanks for your assistance.
Now sorted, issue was low voltage on pin 1, found a crook connection on ignition feed and once fixed was able to obtain connection with correct 5v and interrogate the ecu
Ecu running M48-V60 TC PC running M48-V62 so I loaded 6.0 o to the pc and now all working
I think that means I need to find someone here in Melb with a M48 SUU so that I can upgrade to 6.2 ?????
Cheers Doug
Doug-WG
Postby SprinterTRD on Fri Jun 25, 2021 9:43 am
Glad you found the problem.
M4 & M4-8 use the same SUU, One of the dealers should have one but the next problem is will they have a laptop to run
DOS software!
SprinterTRD
Postby Doug-WG on Fri Jun 25, 2021 11:02 am
Is there software that I also have to locate as well as the SUU?
I now have several PC's that run dos, on Win 98, Win XP and Win 7
Doug-WG
Postby SprinterTRD on Fri Jun 25, 2021 12:10 pm
The M4 install has the upgrade software included.
SprinterTRD
Postby Doug-WG on Mon Jun 28, 2021 6:49 pm
Ok, on to the next step, the existing M48 set up I have was on a twin turbo v6 and I am now fitting it to a twin turbo V8, I have the M48, an ignition expander Motec IEX EPS 0010 and presently 2 X M&W Ignitions ECU3, which I believe are 3 coil ignition modules ie 6 in total and I now need 8
Any suggestions on what I should buy to replace the M&W igniters so as to go from 6 to 8 cylinders ?
Should I go inductive or CDI ? What best suits the existing Motec components that I already have?
Thanks in advance, Regards Doug
Doug-WG
Postby Doug-WG on Sat Nov 18, 2023 1:52 pm
Hi All, Project is finally coming along but now NEED SUU to ugrade software on M4-8
Where can I buy, beg, borrow or steal one? Any ideas would be greatly appreiciated
Regards Doug
Doug-WG
Previous
Return to Old ECUs
