Where are maths stored on my computer?
Postby Lorcan on Mon May 24, 2021 7:28 pm
Where are maths stored on my computer? We have several people looking at the same log file but the units appear different to each person, some have maths applied and I've recently got a new computer that doesn't have the maths functions in it. Is there a maths file that can be copied rather than typing all the functions manually into each computer?
Lorcan
Re: Where are maths stored on my computer?
Postby AlanB on Mon May 24, 2021 7:51 pm
The easiest way to share maths is by using the dedicated import and export function in i2.
So in i2, go to Tools -> Maths, then select the Workspace Maths you want to share and click Export. This will create an xml file which can then be imported in the same manner on the target computer.
Alan Bell
MoTeC Europe Ltd
AlanB
Postby Lorcan on Mon May 24, 2021 8:05 pm
I can't see an export or import button?
Lorcan
Postby AlanB on Mon May 24, 2021 8:07 pm
What version of i2 Pro are you using?
Alan Bell
MoTeC Europe Ltd
AlanB
Postby Lorcan on Mon May 24, 2021 8:16 pm
i2 standard.
Lorcan
Postby AlanB on Mon May 24, 2021 8:23 pm
In that case you need to go to:
user/AppData/Roaming/MoTeC/i2/1.1/i2 Standard/Workspaces/Circuit/Maths
Alan Bell
MoTeC Europe Ltd
AlanB
Postby Lorcan on Mon May 24, 2021 8:41 pm
Sorry to be dense but I can't find that folder on my computer anywhere. I'm using Windows 7 if that makes any difference.
Lorcan
Postby AlanB on Mon May 24, 2021 8:52 pm
It is a hidden folder, so you may need to change your Explorer settings to make it visible.
Open Windows Explorer and go to Folder Options. On the View tab, under 'Hidden files and folders', set it to 'Show hidden files, folders and drives'.
Alan Bell
MoTeC Europe Ltd
AlanB
Postby Lorcan on Mon May 24, 2021 9:03 pm
Got it, thanks.
Lorcan
Users browsing this forum: No registered users and 25 guests
