by AlanB on Sat May 22, 2021 12:17 am
Diagnosing too much engine braking is quite straightforward, all you need to do is compare front wheel speed (or GPS Speed if you don't have a front wheel speed sensor) to rear wheel speed. If the rear speed is more than 10km/h below the front then the bike is probably "backing in", so will require some additional air flow through the engine (via DBW, stepper motor or air bleed valve).
Too little engine braking, where the bike is "pushing" into a corner, is harder to see on the data as the front and rear wheel speeds will be pretty much the same and this is in itself does not indicate that it is pushing. You really have to go by rider feedback and make some big changes in the area they are struggling until you start to induce some "backing-in".
When adjusting engine braking, always make sure you check the rear suspension stroke at the same time, as there is little point in adjusting the engine braking when the rear wheel is off the ground. This situation would require some chassis/suspension changes to rectify.
Alan Bell
MoTeC Europe Ltd
