DBW M130 Pedal position sensor
Postby Aquila on Tue Apr 27, 2021 7:28 pm
HI,I understand its not ideal but are there any down falls, concerns of using a Motec 3 wire Contactless rotary position sensor as a pedal position senor in a DBW set up any safety issues to worry about.
Thanks newbie
Aquila
Re: DBW M130 Pedal position sensor
Postby David Ferguson on Wed Apr 28, 2021 2:52 am
Yeah -- it's not safe!
If the sensor were to fail, and indicate 50 - 100% throttle there would be no way of knowing without a tracking sensor.
So either use two sensors, or just use a dual-output sensor designed for DBW applications.
Postby Aquila on Wed Apr 28, 2021 2:20 pm
Thanks for replying so quickly David
I have arranged to get it removed and get it done correctly.
Thank you.
Aquila
