Hall Sensor or Magnetic?
Postby Giltgy on Thu Apr 22, 2021 8:40 am
Does anyone have an opinion about which of these is better?
Since Motec mentions the use of a hall sensor, I am assuming this
is the preferred sensor? Also, can anyone confirm that the simple
test using a power supply within the operating parameters will confirm
the function of a hall sensor? This envolves passing a magnetic object in
front of the sensor and observing the voltage "switching off".
Best,
Guil
Giltgy
Re: Hall Sensor or Magnetic?
Postby Stephen Dean on Thu Apr 22, 2021 12:20 pm
Hi Guil,
What are you using it for? There are different requirements depending on what is being read.
Postby Giltgy on Sat Apr 24, 2021 12:19 am
I am interested in the crank position sensor application
for my rotary engine.
Best,
Guil
Giltgy
Postby David Ferguson on Sat Apr 24, 2021 2:37 am
I always see magnetic (Variable Reluctance) on rotary racing applications.
Users browsing this forum: Bing [Bot] and 21 guests
