2 rotor 4 coil with an M600
Postby Giltgy on Tue Mar 30, 2021 1:17 pm
Is there any technical drawing besides the M2R ones that
describe the 4 coil setup for a 2 rotor? I am thinking the 140/141
mode described in the M2R notes is what I should be using when
wiring/setting up my ignition? There is a dwg. (M24) which is referencing the
M4-M8 as well, however, since my ecu is an M600 I think the M2R
is what I should reference. Any help would be appreciated.
Motor is full race Mazda 12a-N/A, road racing use
Best,
Guil
Giltgy
Re: 2 rotor 4 coil with an M600
Postby Stephen Dean on Tue Mar 30, 2021 4:17 pm
Have a look at document M47, this is the wiring for the CDI, but it is the way that the wiring is done for Mode 140.
