0-100kph time
0-100kph time
Postby georgemcf on Thu Mar 25, 2021 7:06 am
Hey guys,
Today’s simple question.
Is there a way to setup a 0-100kph time to display in a channel report? Am working on improving starts for a young fellow in a spec class, and want to try a few different things with his starts. So instead of using a datum cursor it would be handy if I could display it as a number in seconds.
Cheers
georgemcf
Re: 0-100kph time
Postby adrian on Thu Mar 25, 2021 9:00 am
There are a couple of options, you could just use the acceleration report, which would be the easiest way. You just have to change the start/end speeds to suit and toggle the result from 'G force' to 'time'.
Otherwise, if you have i2 Pro, you could create an integration maths channel that calculates the time from 0-100. You could then add that channel to your channel report.
Re: 0-100kph time
Postby georgemcf on Thu Mar 25, 2021 9:06 am
Thanks Adrian.
I have a plane ride tonight so will have a play to see how I get on.
George
georgemcf
