Hayabusa rough idle
Hayabusa rough idle
Postby srd700 on Sat Mar 20, 2021 12:06 am
With ref to my previous post, has anyone experienced poor idle on a Hayabusa engine?, image attached.
Cheers
Steve
rpm idle.JPG (47.14 KiB) Viewed 3203 times
srd700
Re: Hayabusa rough idle
Postby David Ferguson on Sat Mar 20, 2021 2:51 am
Is the mechanical condition OK? No air leaks, compression good, clean/new plugs, injector spray pattern tested.
Is it wired correctly? lower / upper injectors aren't swapped or something, injectors / coils wired in firing order not cylinder number.
Do you have any diagnostics errors on ref/sync, injectors or ignition?
Do all sensors values seem reasonable?
