by jeffkraftwks on Thu Mar 11, 2021 5:10 am
I have a porsche 993 engine with a new M84 installation along with ITB's etc. It starts & runs, but there is a relatively long crank to start, and an occasional ref/synch error that randomly shows when running. It has the 60 minus 2 flywheel hall sensor, and a cam mounted hall synch sensor. I added a capture file to see if anyone can suggest a solution? Not sure if the sensor setup is correct, have not done this before. Checked air gap a couple times but not sure what else. Thanks for your help, Jeff
- Attachments
03 10 2021 capture 993 4.0.rsc2
- (64.45 KiB) Downloaded 877 times
