Error Sync RunT
Error Sync RunT
Postby Wolf_Tm250 on Wed Mar 04, 2009 5:54 am
Hello All.
Today I had the first start up, after I replaced my M4 with a new M400, but I got this error ( many times, after I resetted errors, it came out again, maybe at idle ) I never had before...
What is it? Any advice?
Thanks in advance.
Wolf_Tm
Toyota Celica GT-four ST205 - full TTE/WRC hardware
Parma - Italy
http://www.youtube.com/user/WolfTm250
Wolf_Tm250
Re: Error Sync RunT
Postby Martin on Wed Mar 04, 2009 7:27 am
Is this a Mag sensor?
It means that noise levels are very close to your set trigger levels.
Try increase your trigger level slightly at the RPM where this happens.
Re: Error Sync RunT
Postby Wolf_Tm250 on Wed Mar 04, 2009 8:17 am
Martin wrote:Is this a Mag sensor?
Don't know... sorry...
The car is a Toyota Celica GT-four, 3SGTE engine, and I know the TDC sensor is connected to the intake cam, behind the distributor...
Sorry again... how could I do it ?
Thanks a lot, regards
Wolf_Tm
Parma - Italy
Wolf_Tm250
Re: Error Sync RunT
Postby mr2andy on Wed Sep 02, 2009 3:50 am
I know this is an old thread and the problem could have been solved. I have an MR2 with 3SGTE. If you are using the OEM distributor and the ref/sync reside inside the distributor, then yes, it's a magnetic sensor. Both the ref and sync is on the falling edge.
mr2andy
