hello guys can you guys help me on calibration for stock Map sensor
mine reading at 40kpa on idle
what you guys reading?
please help.. thanks
the sensor is DENSO 22027AA510
stevieturbo wrote:get a Mityvac and test it.
Do not guess a calibration.
SDean wrote:If the standard sensors are used, along with the correct calibrations, then the base setup in the Toyota 86 Packages is correct for a stock engine. We have not had any reports for the calibrations supplied not matching up with the standard vehicle.
The mileage on the dash will need to be calibrated on each vehicle as the Toyota 86 Fuel Flow Scale can vary with different vehicles.
