David Ferguson wrote:Does your UTC communicate with the MLS ECU?
Can you confirm there is CAN traffic using your UTC and the CAN Inspector software found in the utilities download.
On your dash, monitor channels and look for CAN Comms Diags XX and report if there are non-zero values.
SprinterTRD wrote:The MLS only has serial comms so this would need to be connected between the two units.
SprinterTRD wrote:That sounds correct MLS-22 RS232 TX to Sport-34 RS232 RX
Now you need to make sure the Sport dash is setup to receive/decode the same Telemetry data set at the correct baud rate that the MLS is transmitting on.
The MLS has 8 different data set options and 5 baud rate options.
Also note that when you are adjusting the MLS Telemetry is turned off so the sport dash wont display anything.
SprinterTRD wrote:You will need a laptop that has a serial port and can run DOS programs so something with XP or Windows7. Windows10 will not work.
Download the MLS software from MoTeC and install it. Get the Sport dash software & install it, the version you need is displayed on the dash when it boots up.
Get a serial cable and connect the laptop to the MLS D9 connector
Run the MLS software & select "Adjust" ( this will connect you to the ECU )
GO to "General Setup" "Miscellaneous Setup 2" ( The telemetry setup is displayed here )
Then you need to connect to the dash via the USB connector and then go to "Online" "Get Configuration".
Then In the "Inputs" "Communications" menu, make sure the RS232 setup matches what is in the ECU.
