M84 Knock sensors
M84 Knock sensors
Postby Jimster on Thu Jan 28, 2021 9:50 pm
Hi There,
is it possible to connect knock sensors to the M84 directly, or would I need an additional interface?
Jim
Jimster
Re: M84 Knock sensors
Postby Stephen Dean on Fri Jan 29, 2021 8:31 am
The M84 does not have support for knock sensors in the hardware and is not able to use an external device for this either as there is no support in the Firmware for any knock control.
Postby Vlad on Sun Mar 14, 2021 2:36 am
You can do a ignition trim based on a 0-5v from a external knock detection device (ex Phormula KS, etc) but is not very effective, as it's only momentarily, and you cannot set the severity of it's reaction... Might save the engine in one or two cases thow
Vlad Pescaru
Vlad
Return to M84 ECUs
Users browsing this forum: Bing [Bot] and 2 guests
