Hi all,
Using an M130 GPA base package on a EJ20 (non-AVCS version 6). I was thinking to allocate an auxiliary output to run a solid state relay to modulate the DCCD unit. To do so, i wanted to utilise a 4d map including TPS/YAW (3d, with duty cycle output) and using speed as the 4th dimension.
Are all auxiliary outputs locked for customization of their relevant inputs? I cannot see any way to use YAW to build a custom auxiliary output map anywhere. I hope this doesn't require a custom firmware setup (or buying a motec diff controller), was not planning on going down that path as the GPA package does everything I require otherwise.
