Hi all
Is there a documented process for upgrading from GPA to GPR, ideally without losing the config?
Thanks in advance
David Ferguson wrote:open a new GPR base config, and your exisiting GPA config with File->Add Compare Package..., then use Tools->Migrate data to transfer the differences. You will end up with a GPR config that has all your existing GPA data. Usually takes only a few minutes to accomplish this.
Users browsing this forum: Baidu [Spider] and 13 guests
