1.05 bar map sensor
1.05 bar map sensor
Postby greenamex2 on Wed Dec 09, 2020 7:58 pm
Hi all
Which M1 predefined sensor do I use to configure the 1.05 bar map sensor (#53000)?
I am currently using the one for the 1 bar sensor (#53001), is that OK?
Thanks in advance
greenamex2
Re: 1.05 bar map sensor
Postby Stephen Dean on Fri Dec 11, 2020 1:52 pm
I have just checked the calibrations for the 53000 and 53001 sensors and the calibrations are the same, the only difference is that the 53000 extends to 1.05 kPa (at over 5V) compared to 102 kPa under 5V with the 53001.
Postby greenamex2 on Fri Dec 11, 2020 6:13 pm
Thought so. Thanks Stephen.
greenamex2
