High rpm cut-out
Re: High rpm cut-out
Postby Stephen Dean on Tue Dec 08, 2020 3:30 pm
Hi John,
The threshold noise that is coming up does not appear to be the cause of the issue, if you change the Engine Speed Pin Threshold and Engine Synchronisation Pin Threshold values to 0.1V this error should clear, if it is being caused by the signal floating around 0.0V. If it is a wiring issue, then this change will not make a difference.
Postby parsonsj on Tue Dec 08, 2020 11:56 pm
Hi Stephen,
Thanks -- that's an easy change to make. I was just looking at those parameters.
Any other ideas what might be causing this?
parsonsj
Postby parsonsj on Wed Dec 09, 2020 12:50 pm
More review of the data shows that the Fuel Mixture Aim goes from .87 to .92LA as the rpm passes 8k on its way to 9k. (you can see it in the posted log)
I can't even begin to find a reason for that. The main table is set to .87 for the entire region, but for some reason the ECU has picked another table and is leaning the fuel mixture as the engine approaches redline...
parsonsj
Postby Stephen Dean on Wed Dec 09, 2020 1:16 pm
I had seen that as well, but hadn't been able to work out the cause.
Postby parsonsj on Thu Dec 10, 2020 10:43 am
Mea culpa: I think I've sorted the cut out: I'm using a PMU now, and the coil circuit limit was set to 5A. By my calculations, based on idle current draw, the PMU would "see" about 5A somewhere around 9000 rpm. And the break strategy was set to "retry", so as soon as the rpm dropped a bit, it would recover. An old-fashioned fuse would have blown, and I would have figured this last week. Gotta get used to the new way of doing things. Many thanks to all for helping on this issue.
However, the rise in Mixture Aim from .87 to .92 remains unexplained. I run Sunoco GT 260 Plus gasoline, which has a US octane rating of 104, so .92 will be fine if it continues to happen. I'm logging Fuel Mixture Aim State, so I should get some better data on the problem on Friday.
parsonsj
Postby Stephen Dean on Fri Dec 11, 2020 9:04 am
Hi John,
That lean spike may have been caused by the coils not firing and no combustion occurring thus affecting the lambda reading.
Postby parsonsj on Mon Dec 14, 2020 8:58 am
The weekend report is that the engine ran nicely all the way to redline . No high rpm cutout, no weird Mixture Aim movement. Seems like this issue is sorted. MoTeC's recommended ITB tuning method worked great.
Again, many thanks.
Wing mirrors, front tire puncture, shifter valves... that's another story.
parsonsj
Postby Stephen Dean on Mon Dec 14, 2020 9:18 am
8-)
Previous
Users browsing this forum: Baidu [Spider] and 10 guests
