GSXR 1000 2005 ref sync capture
Postby Sean on Sun Dec 06, 2020 6:09 pm
Greetings MoTeC folks, would any of you have a ref sync capture with the stock crank and cam sensors you could share with me? I'm trying to sort out some problems, also would help to know if the cam sensor is rising or falling edge. Thanks in advance, Sean.
Sean
Re: GSXR 1000 2005 ref sync capture
Postby Stephen Dean on Mon Dec 07, 2020 9:23 am
Hi Sean,
Do you have a capture from the installation that you have?
Postby Auto Sport Elect on Mon Dec 07, 2020 12:12 pm
HI Sean,
Not the best capture, but this is how I wired a K6 many years ago, and from memory the K5 was the same trigger
Glen
Suzuki gsxr1000k6 Nov 2007.rsc2
(64.45 KiB) Downloaded 963 times
Auto Sport Elect
Postby Sean on Mon Dec 07, 2020 9:37 pm
Auto Sport Elect wrote:HI Sean,
Glen
Glen, that's excellent, just what I needed. Shows we need to find (lots) more cranking speed :shock:
Maybe 24 volts up the starter will liven it up :lol: :lol: :lol:
Fifi cranking.jpg (189.64 KiB) Viewed 7934 times
Sean
Postby Stephen Dean on Tue Dec 08, 2020 8:51 am
Hi Sean,
Rising edge for both traces, and you definitely need more cranking speed as some of the gaps between the single teeth open up enough that they could be counted as a missed tooth.
It also looks like you need to use one of the Gap Based Sync modes with this engine.
68 : Two missing teeth twice per cycle Gap based Sync
Requires active Sync edge to land within missing tooth window and
remain there. Not suitable for active camshaft engines.
69 : One missing tooth twice per cycle Gap based Sync
Postby Sean on Tue Dec 08, 2020 1:38 pm
SDean wrote: you definitely need more cranking speed as some of the gaps between the single teeth open up enough that they could be counted as a missed tooth.
Thanks Stephen, this explains a big lot. Cheers
Sean
Postby Auto Sport Elect on Tue Dec 08, 2020 11:02 pm
Sean, that capture was a pretty powerful GSX-R under ASBK rules, and it always cranked well, and have not seen a Suzuki crank that slow. I would have a look at the starter or cables, something seems off there.
Auto Sport Elect
