CAN output for AEM CD-5 dash
This sub forums is for discussions relating to the MoTeC M1 Diesel Packages
Postby jwickman on Wed Oct 21, 2020 6:48 pm
Hi all
Recently purchased a AEM 5in dash for the hilux to monitor the truck. Is there a specific .dbc file for the diesel package for all the CAN info.
I hope i made this clear enough.
One thing i noticed in the dash software is that the Lambda only reads up to 2.55 the diesel package reads up to 10 is there a way to scale this in the .dbc file so that it reads correctly?
John
jwickman
Re: CAN output for AEM CD-5 dash
Postby adrian on Tue Oct 27, 2020 9:30 am
Hi John,
Below is the .dbc file for the Diesel messaging.
A max value of 2.55 is going to limit what you see with a Diesel a fair bit. You can change the scale in the .dbc file to adjust the range but you will obviously then have to work out in your head what the actual value is when you look at the Dash.
Adrian
M1 Diesel 0x690.dbc
(19.05 KiB) Downloaded 1188 times
Postby jwickman on Wed Oct 28, 2020 6:25 pm
Hi Adrian
I had a look through the .dbc file that you provided and there appears to be a channel called Exhaust lambda large im thinking this will allow the AEM dash to read a value up to Lambda 10 as it allows me to do that in simulation.
Thanks for providing the .dbc file.
regards
John
jwickman
Postby jwickman on Tue Feb 09, 2021 11:41 am
Hi Adrian,
Just curious but that .bdc file you provided is that the latest version for the 1kd package.
John
jwickman
Postby adrian on Wed Feb 10, 2021 2:44 pm
Yes that is the latest one
Return to M1 Diesel
