Hi guys,
I'm working on MoTeC m800 fit into Toyota 1UR-FE 4.6L engine in test bench.
I'm facing problem that doesn't running engine with "Error Sync Signal" when cranking, and I did ref/sync capture (refer attach).
Ref/Sync sensor setup are below,
Ref/Sync Mode: 43
Crank Ref Teeth: 36
Tooth Ratio: 50
Crank Index Position: 125.0
REF Sensor Type: 1
REF Sensor Edge Polarity: 0
REF Trigger Voltage: 0.0
SYNC Sensor Type: 1
SYNC Sensor Edge Polarity: 0
SYNC Trigger Voltage: 0.0
The same type engine previously ran without problem under the same setup value.
I'm concerned 0 voltage offset...of course confirmed sensor ground for the sensors goes to the pin B16, and ECU ground pin A10 and A11 are connected engine block.
Anything else I'm missing?
Thank you in advance.
Yuji
