by Lsi on Fri Oct 09, 2020 3:25 am
Hi guys, having this code on a SC k24 , scalled the 4 bar map and as soon as it sees a bit more load it throws "manifold pressure error". Engine seems to run fine , also compared the reading with a zeitronix zt2 with a 5 bar map and numbers match . Cant seem to find a way to log sensor voltage on the software. What could throw such code? Also in struggles a bit to start on cold and it stays pig rich for around a minute or so, but that migh be sync issue and corrections, anyways heres my basemap if you guys cold take a look. Thanks.
- Attachments
lotus MUITO BOM_2 1050x_SC 4bar map TESTE.e35
- (72 KiB) Downloaded 1044 times
