by Stephen Dean on Wed Sep 23, 2020 10:01 am
Hi Ben,
The Lap GPS Beacon x values are used to allow for a set of custom beacons to be used with the M1, the co-ordinates for all of the tracks that we have data for (matches that in the Dash software) is embedded into the M1 firmware and will automatically detect the correct beacon when the GPS co-ordinates align.
Are you running the GPS directly into the M1, or is it coming in from a external device, such as a MoTeC Dash? You need to ensure that the GPS Valid channel is reading as Valid, if it isn't then the Lap function will not work.
