Hello everybody,
I just found this phorum, and this is my first message.
I have a problem that it is driving me crazy.
I am using a MOTEC 800, and a LSU 4.0 lambda for data logging. I don't use closed loop.
Always, with the engine started or stoped, the lamba status is OFF, that means that the lambda is not heated and it is giving all the time 1.5/1.7 lecture, when it should be around 0.9
The lambda is well connected, there is not any error alert about it, and I can log the lambda data.
How can I turn the lambda status to ON? I have searched all the menus in the map file and I can not find how to do it.
I also have another problem, I am using a 2D display. I send the motec data to the 2D display via CAN and everything is ok.
The only question is that I must have the MOTEC USB-CAN cable (the one I use to connect my laptop with the MOTEC) pluged on the motorbike all the time. If the cable is connected everything is all right, if I remove the cable, the CAN communication between the motec and the 2D display fails. Do you have any idea about which is the problem?
Thank you in advance, best regards,
David
