So i have done a simulation in display creator and used a log file from i2 to simulate and see what channels come through. It turns out that i am not receiving fuel closed loop trim. Here is the background on my project:
Running a motec m1 plug and play kit for 2016 skidoo xs 1200. In m1 and in i2 i log " fuel closed loop control trim" and it moniters fine.
I am preparing to run a c127 dash and have loaded m1 general 0x640 and 0x650 version 3. In the list i can only choose between fuel closed loop ctl b1 trim and fuel closed loop ctl b2 trim. There is no " fuel closed loop control trim" listed like my pkg has. I made a display creator layout that ibam going to run and when i simulate off the i2 log file everything works and displays except for closed loop trim.
Is the problem the pkg because the channel is not called "fuel closed loop ctl b1 trim"? Or does the dbc file need to be updated to accept the skidoo channel "fuel closed loop control trim?
I havent received my dash yet to actually test in reality but so far i dont think the dash will be recieving the trim channel from the skidoo m1 pkg... any ideas or just wait for the dash to arrive and test?
