Aerodynamic coefficient of drag (cdA) and wheel drag
Postby Holmz on Wed Feb 25, 2009 10:53 pm
Is there a provision in i2 for computing the aerodynamic coefficient of drag (cdA) and wheel drag?
If I know the speed and mass of the vehicle and do a coast down it is mathematically possible to do this.
(Just hopping it is i2 possible)
Holmz
Re: Aerodynamic coefficient of drag (cdA) and wheel drag
Postby JamieA on Thu Feb 26, 2009 8:55 am
There is no pre-defined function to do this. If you have the understanding, you should be able to creat the calculation in either maths, or using a custom function.
JamieA
Postby RossB on Mon Mar 02, 2009 1:14 pm
Some calculations I use are:
Rolling resistance horsepower = 0,013xVehicle weight (lbs)xspeed (MPH)/375
Air resistance horsepower = frontal area (sq ft) x Cd x 0.00256 x (speed (MPH) cubed)/375
Not exactly what you are looking for but if you know frontal area and power you could reverse the calculation to give Cd.
RossB
Postby Holmz on Mon Mar 02, 2009 1:55 pm
RossB wrote:Some calculations I use are:
Air resistance horsepower = frontal area (sq ft) x Cd x 0.0256 x (speed (MPH) cubed)/375
Thanks Ross,
Where do I get documentation on how to use the external maths with i2?
I think that is probably where I should start.
Holmz
Postby gixxer_drew on Tue Mar 03, 2009 3:52 am
I'm getting some odd results with that calculation
I put it into excel like this
20*0.32*0.0256*150^3/375
150 corresponds to speed in MPH
0.32 Cd
20sq/ft frontal area
=1474 HP?
What am I doing wrong there?
gixxer_drew
Postby RossB on Tue Mar 03, 2009 4:24 pm
Oops! I made a typo in my calculation, it should read:
Air resistance horsepower = frontal area (sq ft) x Cd x 0.00256 x (speed (MPH) cubed)/375 so the result wouild be out by a decimal point! The 0.0256 should be 0.00256. I will edit the original post with the correct number.
RossB
Postby Holmz on Tue Mar 03, 2009 8:45 pm
Thanks Ross...
I am doing it the other way around - so I'll measure the speed and roll the vehicle down and get the cdA (coefficient * area) as well as the wheel drag, with both of those based off of empirical measurement.
So (time permitting) I should have a a follow up in a few weeks...
Holmz
