I am in need of some advice/solution for my Skidoo snowmobile with a M130 plug and play kit. I dont have the daah yet, i want to confirm this will work.
I want to run the c127 dash which means i will remove the factory dash. The only issue is that the factory dash controls the hand and thumb warmers. It appears the c127 should be able to run these but I need a little help on how to accomplish this.
Background on the factory system:
The factory system uses 2 momentary rocker switches. 1 for thumb and 1 for both hand grips- you rocker up for more heat and rocker down for less. The factory cluster displays the heat setting for the grips and throttle lever( each has there own display) in a 5 bar block display that goes up and down with heat setting. 0 blocks is no heat and 5 ia full heat..basically 5 heat settings. The cluster has 2 output wires for the grips and lever. The cluster supplies B+ power to the heaters and I am guessing it outputs a variable voltage for this. Total amps is 4 for the warmers and a little less for the thumb.
So far this is what I have come up with for a solution. I am no electronic expert but let me know if this is correct or wrong.
I made 4 new channels:
Grip heat up
Grip heat down
Lever heat up
Lever heat down.
The channel units is on/off and display units is on/off. I added these channels to AV2,3,4&5.
Next i made a counter channel for grips and 1 for lever. For each counter i added the appropriate up and down input switch. The type is up/down and min value is 0 and max is 6 because i want 6 heat settings. So far so good?
I then made bar 1 follow lever counter and bar 2 follow grip counter. Style is moving indicator with left value 0, intermediate 3 and right 6. Is that correct?
Now this is where i am not sure what to do.
Output-
For output, I assign 1 aux output for each heater. The output mode will be duty cycle control. The duty cycle channel will be grips/lever counters. I would change the 0-6 input counter value to be a value representing duty cycle... 0= 0%dc 6=100%dc??
Then use a SSR? I am not experienced enough here but if anyone can give me some tips or direction would be great!!
Greg
