Feedforward component in PID tuning (DBW)
Postby VSCM on Tue Feb 04, 2020 7:58 pm
Hi all. While I was tuning a pid (drive-by-wire) on my m800 I noticed the section "feedforward". I know that feedforward consists of sending a percentage of the input directly to the output with no control action.
How does this affect the behaviour of the system? How can I choose the correct value while tuning the PID without damaging the ETB? Using the feedforward component could reduce the lag between TPD and TPS?
Thank you for your support.
VSCM
Re: Feedforward component in PID tuning (DBW)
Postby Blu302 on Sun Mar 29, 2020 9:22 pm
The feed forward is used to counter against the return spring.
The safest option is to get Motec to tune it if they don't have the settings already.
The lag between the TPD and TPS is from the PID being slow. When Motec tuned my BMW throttle for my M800, it reacts faster than you can move with your foot. I was shown this using hand input with a twitch, which it followed perfectly.
Blu302
Blu302
Postby Vlad on Fri May 01, 2020 1:34 am
Yep...ask MoTeC for that info...it’s quite risky to do it yourself
Vlad Pescaru
Vlad
Postby Blu302 on Sat Jul 11, 2020 10:55 pm
If the "system" doesn't track fast enough, it will go into fault and shut down the DBW
Blu302
Blu302
