Ref Sync Modes
Ref Sync Modes
Postby prule on Thu Apr 30, 2020 1:51 pm
I have an M48 and am trying to work out what the differences are in certain Ref Sync modes.
Some types have a range, eg 1-4, 11-14, 71-74 etc.
So, what are types 1,2,3,4 and 11,12,13,14 ?
Is this to do with the combination of ref and sync sensor type? eg If the Ref is a hall sensor and the sync is a mag sensor and one is a rise type and one is a fall type?
I can't find a table explaining this in the help, just some odd mentions of it in this forum.
Would help, as I'm experimenting with different combinations at the moment.
Paul
prule
Re: Ref Sync Modes
Postby adrian on Thu Apr 30, 2020 6:00 pm
The help for ref/sync mode - general is where you will find the table (see below). The ranges are always in the same order, so for example 71 is rise/rise 72 rise/fall etc etc
Re: Ref Sync Modes
Postby prule on Fri May 01, 2020 2:40 pm
Awesome!
Thank you. That's exactly what I was looking for.
prule
Re: Ref Sync Modes
Postby terryo on Wed Apr 20, 2022 7:03 am
could someone please give me a link to that help pop-up. its nothing like what i get on either of my M4 or M48. i am trying to sort out same issue. thanks
terryo
Re: Ref Sync Modes
Postby David Ferguson on Wed Apr 20, 2022 7:58 am
You can see the path to the help in the help window title bar. So open EMP, Use Adjust, then General Setup, then Main Setup, then select the Ref/Sync Mode line, and press F1. When the windows pops up asking for which help, choose the first line "General". Then use the up/down arrow keys to scroll
