by David Ferguson on Tue Apr 14, 2020 11:39 am
So your sensor will produce 13 / 8 = 1.625 pulses per revolution.
At 100000 RPM, this would be 1.625 x 100000 / 60 (seconds / min) = 2708 pulses per second (known as hz).
So, add your E888 to the Devices, then select the Turbo Speed channel for the digital input that it is connected to. You will need to create a custom calibration since there aren't an integer number of pulses per revolution. The table will have 0hz / 0 RPM, and 2708hz / 100000 RPM.
Here is a calibration you can use. Just select Load..., then use Import... to bring it into your list of calibrations.
- Attachments
- BorgWarner 13blade-divide8 sensor.zip
- (274 Bytes) Downloaded 756 times
