M130 GPR Motorcycle
M130 GPR Motorcycle
Postby mick41zxr on Mon Feb 24, 2020 10:33 pm
Looking to upgrade to M130 ECU, while some base packages for the 130 are available on Motec Online I cannot find the M1 130 Motorcycle base package. Is it possible to view a copy to see its capabilities.
I see from the spec sheets that the knock sensor inputs have been re purposed to suspension potentiometer inputs.
Are these set that way in this build, or can knock sensors be used to set base timing & later the suspension pots be fitted for the track.
Thanks,
Michael
mick41zxr
Re: M130 GPR Motorcycle
Postby Stephen Dean on Tue Feb 25, 2020 5:02 pm
The GPR Motorcycle Package is in final beta testing at the moment, once this is done we'll release it publicly.
The Package is quite comprehensive and uses a lot of resource on the M130, hence why the Knock Sensor resources have been repurposed for Suspension Position monitoring. These can be moved back to being used for knock detection if desired.
Postby mick41zxr on Tue Feb 25, 2020 10:55 pm
Thankyou Stephen,
Do you have a rough eta on the release of that package.
Regards,
Michael
mick41zxr
Postby Stephen Dean on Wed Feb 26, 2020 10:25 am
Hi Michael,
I have asked about this Package, it can be ordered from a MoteC Dealer if you want, and they are doing a final review on it now so it should become a Public Package shortly.
CDS23358_GPR_Motorcycle_Package.pdf
(580.78 KiB) Downloaded 831 times
Postby Sean on Mon Mar 16, 2020 10:41 pm
Stephen, I'm getting "download not available". Has the package been withdrawn temporarily?
Sean
Postby Stephen Dean on Tue Mar 17, 2020 8:56 am
Hi Sean,
We migrated the forum to a new server last week and some of the file attachment links got broken in the process, we had fixed most of them but it appears that this is one that was missed. I have reattached the file.
(580.78 KiB) Downloaded 1005 times
Postby Sean on Tue Mar 17, 2020 12:21 pm
Thanks Stephen
Sean
