M150 (GPRP) - Closed loop gear shift
Postby VSCM on Sat Mar 07, 2020 4:16 am
Good evening, I'm trying to configurate the closed-loop control for gear shifting instead of open loop.
The car is equipped with GPRP and a gear position sensor.
How can I specifiy to the ECU that I want to use the closed-loop mode for the gear shift? Will the ECU automatically understand this once the gear position sensor is detected? At the moment I haven't got the pshysical ECU (I have to wait for the shipping).
Thanks a lot in advance, I hope that you can help me.
VSCM
Re: M150 (GPRP) - Closed loop gear shift
Postby br21 on Sun Mar 08, 2020 6:44 am
By default the ECU will work in closed loop if you will set the gear voltages, etc
br21
Postby VSCM on Thu Mar 12, 2020 3:08 am
Thanks a lot for replying.
VSCM
Users browsing this forum: Google [Bot] and 13 guests
