Is it possible to use the inputs of the e888 and make a table for the inputs in the dash?
suspensions sensors in example.
if so is there a can protocol whats being sent out?
David Ferguson wrote:You configure the E88 using the C127 Dash Manager. Open your configuration and select Connections->Devices... Use the "Edit.." pop-up in the lower left corner to Add an E888 device (and give it a name). Now you will be able to select the channels on the E888 just like they were internal channels on the C127. Configure/Calibrate them and use the channels for display or other uses.
Return to Accessories and other MoTeC products
