Hi all,
Can anyone give me some idea on how to wire a 2-wire bosch knock sensor to the M130?
Cheers
Andy
SDean wrote:Hi Andy,
To set it up as a Differential Knock input, you connect one of the pins to B7 and the other to B13, this allows for the knock signal to float and helps to provide for a smoother signal that is not as susceptible to external noise. the other alternative is to wire one of the pins to B7, and the other pin to one of the ECU 0V pins, this can effect the signal if another sensor that shares the same 0V adds noise to the pin.
We also recommend that shielded wire is used for a knock signal where possible, or using twisted wires as a minimum.
Users browsing this forum: Bing [Bot] and 2 guests
