M84 injector Peak error for injector dynamics injectors
Postby Rickybobby on Sat Jan 04, 2020 11:35 pm
Please help
I Have a RX7 FD 13B REW engine
I have changed the ECU to M84 running primary and secondary injection
The problem I am having is setting up a base map to start the vehicle
It is running but badly
Under diagnostic screen the fault codes are
Error Injector 1 Combined Peak
Error Injector 2 Combined Peak
The injectors are Injector Dynamics 725 (primary)
And 2000 secondarys
Does anyone know the settings I should be using for these injectors
IJPU setting
Thanks in advance
Rickybobby
Re: M84 injector Peak error for injector dynamics injectors
Postby Rickybobby on Sat Jan 04, 2020 11:38 pm
Also this is my first post so I appogise if its listed in the incorrect place
Rickybobby
Postby Stephen Dean on Tue Feb 11, 2020 8:52 am
Hi Ricky,
I have added the data for the dead times for the two injectors that you have.
IJPU should be 10.
ID2000 Customer sheet.xlsx
(54.23 KiB) Downloaded 961 times
ID725 Customer sheet.xlsx
(170.06 KiB) Downloaded 814 times
Postby Rickybobby on Tue Feb 11, 2020 8:59 am
Thats Great
Thanks for the reply
Rickybobby
Return to M84 ECUs
Users browsing this forum: Google [Bot] and 7 guests
