z0mgchris wrote:Hi,
Pending your TC8 is setup correctly to use setting 1, it should work straight out of the box as E888 > Can1 then set the thermocouples.
I've had no issue using my own personal TC8 on an m130GPR with C127+PDM30+LTC on the same network. Worst case, post your package file and I can compare it to my m130 one thats working.
z0mgchris wrote:I just opened it and have noticed, your ECU is using 1.00.0005. that GPA Package can be upgraded to 1.10.0075 (There is probably a 1.11 update but not certain).
I would recommend doing this upgrade and retesting your issuesthey might be fixed without actually having to look too deep.
if you have any issues still, im happy to dive in again once you're updated! (you may need to request the license upgrade -free- from motec. Just send an email to support@motec.com.au with the serial number etc
