Package Updates m130 GPR
Postby Anthony on Thu Oct 10, 2019 4:40 pm
I have followed the version migration doc - technical note CTN0033 and end up with Feb 2016 - 1.10.0075
https://www.motec.com.au/filedownload.p ... docid=5901
I been looking to find the Cruise control function tab in Tune but can't see it anywhere so must be doing something wrong as according to the doc, I should end up with July 2019.
Ive checked Motec online and all packages here seem to only be the Feb 2016 - 1.10.0075 version also...
Anthony
Re: Package Updates m130 GPR
Postby Stephen Dean on Fri Oct 11, 2019 10:52 am
This Tech Note was uploaded into the wrong section and shouldn't have been made publicly available, it has now been removed.
Postby greenamex2 on Fri Oct 11, 2019 6:38 pm
:cry:
greenamex2
Postby Anthony on Mon Nov 18, 2019 5:30 pm
I see this has now been released, there is talks in the help file on the cruise control
Component around warning lights and cruise targets etc on a motec dash via can, is there some updated can templates to be released at some point as I can’t seem to find these.
Anthony
Postby Stephen Dean on Tue Nov 19, 2019 12:11 pm
Hi Anthony,
The templates are being updated at the moment, and will be available shortly.
Postby greenamex2 on Wed Nov 20, 2019 8:03 pm
Huge thanks...looks like I need to upgrade to GPR ASAP...to help save my driving license (a lot of speed cameras in the UK!)
greenamex2
Postby Stephen Dean on Fri Dec 06, 2019 4:46 pm
Attached is a dbc file that can be imported into Dash Manager to add the Cruise Control messages that have been added to the GP packages. This is a temporary solution until we can make proper templates.
One issue is that Dash Manager selects the wrong resolution for the two speed channels so you end up with 1km/h resolution instead of 0.1km/h resolution. The actual channel value will be correct, just a lower resolution. You can manually change this to 0.1 and make the divisor in the CAN template 1 instead of 10.
M1 General - Cruise Control 0x661.dbc
(2.26 KiB) Downloaded 1572 times
Postby greenamex2 on Sun Dec 08, 2019 8:43 am
Any plans to supply keypad stickers to match the permissible key combinations?
greenamex2
Postby Stephen Dean on Mon Dec 09, 2019 12:07 pm
It's being investigated.
Postby Anthony on Tue Dec 10, 2019 1:41 am
Thanks Stephen, much appreciated
Anthony
Users browsing this forum: Bing [Bot] and 11 guests
