Quick Lambda and Closed Loop from a 5 wire?
Postby Flow on Tue Nov 26, 2019 3:05 pm
Hi folks,
Has anyone been able to get closed loop or quick lambda working on an M4 with an analogue output from a third party 5 wire sensor controller?
Flow
Re: Quick Lambda and Closed Loop from a 5 wire?
Postby AdamW on Wed Nov 27, 2019 9:45 pm
Yes, it works fine. From memory you need the advanced options to access the user defined calibration and the other gotcha is the lambda input can only take a max of 1.2V, rather than the 5V that the help file states.
Motorsport Electronics Ltd.
AdamW
Postby Flow on Fri Nov 29, 2019 6:33 am
Thanks Adam!
I have asked AEM if is it possible to configure the 0-5V output on the 30-0300 to 0-1V as per the 30-4100. If not I assume a voltage divider will do the trick.
Flow
Postby AdamW on Fri Nov 29, 2019 12:05 pm
A bit more info in this thread: viewtopic.php?f=10&t=3442
On my one I used a 5:1 voltage divider from memory made up of a 12K & 3K resistor.
AdamW
Postby Flow on Mon Dec 02, 2019 7:27 pm
Great info Adam, thank you!
Flow
Users browsing this forum: No registered users and 37 guests
