Video problem
Video problem
Postby emidiaz_182 on Wed Apr 24, 2019 1:02 am
Hello, i need help with this, im using i2 std, c187 and v2 camera, some time ago all was working good, but now i cant see the video, i select any data and is the same with all, i hear the sound perfectly but the video dont work, if i create i new tab in workspace with video, it work, but when i change the highlight tab and come back to the video, again not work and the space for video stay like freeze with the word or image that was on top, if i try the video in other player works fine, already try re install i2 std and ffdshow codecs many times, im using windows 10 64bit. thank you
emidiaz_182
Re: Video problem
Postby konastab on Wed May 01, 2019 4:13 am
Hi there!
I'm facing exactly the same problem. First the Video was working fine. but when I re open my recent workspace, the video just stay black. I could here the sound (so I guess i2 knows the correct file). And sometimes, like on my screenshot, the video window just shows artefacts from different screen regons.
THX for any help!
konastab
Re: Video problem
Postby Stephen Dean on Thu May 02, 2019 2:53 pm
Can you let me know the Windows language versions that you are using thanks.
Re: Video problem
Postby konastab on Sat May 04, 2019 2:20 am
Hi sDean,
Thank you for your help!
In my case I have WIN10 Pro english, with an Nvidia 1080 Graphic card.
Is there anything else I could provide?
BYe
Patrick
konastab
Re: Video problem
Postby David Ferguson on Sat May 04, 2019 2:52 am
Do you have any other applications running that might be trying to use the Video Processing hardware (ie, games, video chat, video players, web browser)? If so, any change if you close those applications.
Re: Video problem
Postby konastab on Sat May 04, 2019 7:35 am
No - only i2. Nothing else. I have also checked, if Windows or anything else is downloading updates in the background. But no..
Thanks for any help
konastab
Re: Video problem
Postby halsey1006 on Thu Oct 17, 2019 3:02 pm
I'm also having this exact issue, with an nvidia GTX 1070 driving the display. If I switch over to my onboard Intel graphics using the same monitor with the same PC the issue goes away, so something nvidia seems to be the cause. I have this workaround now but a real fix that doesn't require swapping cables would be great.
halsey1006
Re: Video problem
Postby djangopass on Mon Dec 16, 2019 6:42 pm
Hi I have exactly the same problem. I can only listen to the audio but I do not see the video.
I have also installed the FFDShow Codec as suggested by Motec, but nothing changed. I have Window 10 with a nvidia RTX2070.
Any suggestion?
djangopass
Re: Video problem
Postby marksdoran on Tue Dec 17, 2019 12:55 pm
Add me to the list of people with this same set of symptoms. I updated the video driver (which apparently I needed to do for some other software that didn't like the old one) a week or so ago and where i2pro was able to show me video no problem on this system, now it cannot. All I get is audio at the moment.
I have a second system and when I test on that using the same i2pro version and workspace/data/video file combination everything looks as I'd expect it to...that's an Intel GPU system and the system that doesn't work properly all of a sudden has an NVidia GTX 1080 Ti.
Interestingly, if in i2pro I go into the video component properties, edit the camera view and then in that dialog box highlight the video file (the correct one for the session is found, btw), then the video shows and plays just fine in the itty bitty preview window...it just doesn't play in the main worksheet display. Not sure if that helps troubleshoot or not but it might give someone a clue perhaps??
Oh, and the MP4 file plays directly in VLC perfectly on the NVidia-equipped system outside the context of i2pro also in case that is a question.
marksdoran
Re: Video problem
Postby Stephen Dean on Wed Dec 18, 2019 8:37 am
We are in the process of sourcing some of these video cards so that we can test for this issue and find a resolution to it, it appears to be related to a narrow set of video cards in Windows 10.
