Toggle Wiper Control with PDM30 and CAN Keypad
Postby CommitConfirm on Sat Mar 23, 2019 12:52 am
Hi, I have a PMD30 and the 15 button CAN keypad in my classic Mini. I would like to be able to use a single button on the CAN keypad to toggle through the individual wiper speeds of the stock wiper motor.
I note that in PMD30 user manual it states that hardware you can directly drive the wiper motor form the PDM with outputs 9. Therefore I have used Output 9 & 10 for the fast and slow windings.
Off -> Slow -> Fast -> Off
I'm struggling with the logic of the function to do this so through I would come here and ask for help. If this something anyone has got working before please?
Wiper Motor Pinout
Screen Shot 2019-03-22 at 13.48.55.png (107.56 KiB) Viewed 11186 times
PDM30-wiper_control.pdm
PMD30 Config
(47.57 KiB) Downloaded 1060 times
CommitConfirm
Re: Toggle Wiper Control with PDM30 and CAN Keypad
Postby adrian on Mon Mar 25, 2019 10:16 am
Create a new function, and change it from condition to counter in the drop down box. Use the keypad button as the increment channel and set the maximum count to 2 (see below example).
Then in your outputs make output 9 active when 'fn.Wiper.Mode' == 1 and output 10 active when 'fn.Wiper.Mode' == 2.
Just remember to make sure in the setup for output 9 you select the output for the high speed winding.
Wiper Mode.png (16.36 KiB) Viewed 11139 times
Postby Stephen Dean on Mon Mar 25, 2019 11:36 am
My PDM30 is setup the same way, using a single button on the keypad to cycle through the operating modes. I have stripped out all but the wiper functions and attached the PDM config for you.
See my post further down the topic for the latest updated file.
Postby fun123 on Sat Oct 05, 2019 9:56 am
I downloaded this file to use but I get the following message; Error parsing file C:\Users .......
I am running the latest software 1.9.1.0012
Do you have a file that could work with this software version?
Paul
fun123
Postby Stephen Dean on Mon Oct 07, 2019 9:45 am
Hi Paul,
Try this version, I have also added a wash function to it.
Wiper with Wash.pdm
(50.25 KiB) Downloaded 1186 times
