New version of build broken modules
Re: New version of build broken modules
Postby aNinjaneer on Sat Oct 05, 2019 9:29 am
This package has been under development since 2017, and has been continuously updated, so starting from a new base file is not an option. I don't know which original version it started as.
I downloaded the newest build of M1 Build (1.4.0.239), and all of the previous errors went away, however, now when I try to validate the project, I get an error message pop up that doesn't go away after 100+ times clicking OK--I assume because there are 100+ warning messages. It says "Program Warning. Internal Warning - Notification delivery blocked."
Screen Shot 2019-10-04 at 5.21.19 PM.png (289.31 KiB) Viewed 12232 times
aNinjaneer
Postby aNinjaneer on Sat Oct 05, 2019 11:32 am
I ended up having to force quit the task with task manager. I tried again, but am getting all sorts of internal object errors and "Error 1038: constant value does not exist.".
Screen Shot 2019-10-04 at 7.29.21 PM.png (251.47 KiB) Viewed 12231 times
aNinjaneer
Postby rntechnologies on Thu Oct 10, 2019 11:26 am
Click on the boost object within your project, and have a look on the right hand side at the properties.
You will likely find there are items that either haven't been set, or are set incorrectly.
With the update of the boost module, there are additional items that need to be set in order to function correctly.
Incorrect settings in this object, will affect the rest of your project in the way that your screenshot shows.
Regards,
Ryan
Powertune Australia
rntechnologies
Postby PQatPIT on Mon Nov 04, 2019 8:27 pm
Any news with this?
PQatPIT
Postby rntechnologies on Tue Nov 05, 2019 7:34 am
Have you completed the above steps?
Regards,
Ryan
Powertune Australia
rntechnologies
Postby aNinjaneer on Wed Nov 13, 2019 4:16 am
Yes, but I could not get the newest package versions to work. I ended up reverting back to older versions. At this point, I'm just not going to update any modules, as it seems to break things every time. It would be nice if MoTeC allowed us to develop our own modules.
aNinjaneer
Previous
Return to M1 Build
