by mila on Mon Oct 07, 2019 12:43 pm
Hi guys,
The transmit from DC works a little differently than expected, and uses the internal CANbus. In Communications setup within Dash Manager, you must choose the "Display" tab (not CAN 1-4). Within this display tab, create a new template and set the Device to "Receive Message". Configure the address to whatever you have setup in DC. Then in the "Received Channels" tab add a new channel and set it to whatever you like.
To then transmit this channel to another device, transmit it from the dash. Direct transmission to other devices from DC is not supported.
I've attached a very simple project showing a timer created in DC being transmitted to the Dash via the internal CANbus, and then transmitted out via the Dash on CAN1. You will need C185 Manager 6.11M and DC 6.1.2.142 Beta installed to open these.
Let me know if you have any further questions.
- Attachments
Demo_Tx_Internal.dcproj
- (279.74 KiB) Downloaded 1228 times
Demo_Rx_From_DC.c185v61
- (864.73 KiB) Downloaded 1136 times
Mila Koscialkowska
